Zaslal: po leden 28 2008, 17:13 Předmět: TV Philips 14PT6107P/58
Zdravim, prosim o radu, mam TV Philips 14PT6107P/58 je to tv kombinovane s DVD. ked dam donho dvd, tak mi vypise "wrong region"
neviete ako by sa to dalo spravit? nemam od toho ani service manual, ze by som sa pozrel ako sa tam da nastavit region! Dik za rady!
dik, aspon viem zeby to malo brat vsetky disky, ale preco to neberie ziadne? a cosa tyka servisneho manualu, tak ten tam nikdy nebol, tam su iba uzivatelske!
Tak do serv.menu u TV namačkat 0-6-2-5-9-6-i-+,ale u DVD podržet STOP na DO a PLAY na přistroji 5 vteřin asi. Pak je otazka co se zobrazi.Podivej na http://www.videohelp.com/dvdhacks// něco tam je.Jesli maš na to tak programovat-zde navod(bez zaruky,ne vim co tam maš za střeva v te kombinaci To start service test program hold "<<" button depressed
while set is in standby and press the STANDBY button*
Display shows the ROM version "SVxx-yy" S refers to Service Mode
V refers to Version xx refers to Software version number of the back uProcessor (counting up from 01 to 99)
yy refers to the front uProcessor version number
(00 will be displayed if there is no front uProcessor use)
SERVICE TEST PROGRAM
* Mains power to set must be on
Hold "<<" button depressed till the Display shown "SVxx-yy"
EEPROM FORMAT TEST "<<" Load default data. Display shows "NEW".
Caution! All presets from the customer will be lost!!
Procedure to change Tuner Grid (not for all versions)
1) Power up the set and select TUNER source.
2) Hold "PLAY" button depressed while set is in standby
and press the "STANDBY" button.
3) Hold "PLAY" button depressed till the display shown
'PHILIPS->FM' followed by display the new tuning grid
'GRID 9' or 'GRID 10'.
Note: Repeating the same action will toggle back to its
previous tuning grid setting.
Reprogramming of DVD version Matrix
After repair, the customer setting and region code may be
lost. Reprogramming will put the set back in the state in
which it has left the factory, ie. with the default setting and
the allowed region code.
To reprogram do as follows:
1) Power up the set and select DISC source.
2) Open tray by press "OPEN/CLOSE" button on the set
or press and hold "STOP" button on the RC.
3) Press the following buttons on the Remote Control:
<9> <9> <9> <9> <AUDIO> <1> ......... for LX3900SA/01
<9> <9> <9> <9> <AUDIO> <2> ......... for LX3900SA/05
<9> <9> <9> <9> <AUDIO> <3> ......... for LX3900SA/69
<9> <9> <9> <9> <AUDIO> <4> ......... for LX3900SA/75
<9> <9> <9> <9> <AUDIO> <5> ...........for LX3950W/01
<9> <9> <9> <9> <AUDIO> <6> ...........for LX3950W/05
4) The display shows 'YYYY-ZZ' and the tray will close.
YYYY = model number (eg. 3900, 3950, etc.)
ZZ = stroke version (eg. 01, 05, etc.)
Procedure for check Software version
3) Press "OSD" button on the Remote control.
4) The TV screen will shows:
SD6.1 Vxx YYYY-ZZ P QQ
SERVO: GGGGGGGG REG:D
xx = version number
P / D = region code
QQ = version number of front uProcessor
GGGGGGGG = version for servo code
Procedure to upgrade software
3) Place upgrade CD-ROM onto tray and close.
4) The set will response and display the following:
- LOAD [After the disc is read, the tray will open for
you to remove the disc]
- ERASE
- WRITE
- ERROR [if upgrade is unsuccessful]
- UPG END -> PHILIPS [if upgrade is successful]
- DISC->CLOSE->LOAD [Tray will close indicating
that the upgrade process is completed]
5) The whole process should not take more than 5
minutes.
Caution: Do not unplug the set until upgrade is completed.
Trade Mode
Trade mode is a feature that will block all set keys when
enabled. It is for dealers to prevent customers from
removing disc, changing source etc using the set keys.
Rotary and Remote Control (RC) keys are still allowed in
Trade mode.
To activate Trade Mode:
3) Then press buttons <2> <5> <9> on the RC.
4) The display shows 'TRA ON' and the tray will close.
Trade Mode is now enabled.
To deactivate Trade Mode:
2) Open tray by press and hold "STOP"button on the RC.
4) The display shows 'TRA OFF' and the tray will close.
Trade Mode is now disabled.
Diki moc sasaopravar! bolo zapotreby natukat 0,6,2,5,9,6 a stlacit menu, zvolit DVD a tam dat kod region 00 vyst z menu, vypnut TV do stend-by, znovu zapnut, a DVD ficííí. Super, a dakujem ti velmi pekne za radu!!!
