LG 32LX2R, chassis ML-051A, power supply
aaron77
Založen: Apr 01, 2019
PříspěvekZaslal: po duben 01 2019, 9:45    Předmět: LG 32LX2R, chassis ML-051A, power supply Citovat
Hello.
This TV cannot then be turned on when the power goes out. Doesn't go 5V section.
Breaking, inspecting, and folding the branch will jump. Then I tried to turn off the mains, let go for 0.5h and turn it on.
Once in STBY mode it turns off the current for the morning and the end.
Break down - fold.
The second time the fuse on the house was thrown out and the end was over.
Every time I sold what I could - he saw it with a watchmaker's watch and found nothing.
All we have to do is to find a 5V branch and try to replace the horses or something.
But I don't have the scheme - the repair shop will replace the source for 6 liters and it doesn't pay off.
So please for advice or schematic resource - or. only parts of STBY.
Thank you.[/code]
Heno
Založen: Mar 21, 2015
PříspěvekZaslal: po duben 08 2019, 11:22    Předmět: Citovat
Toto sa mi zdá v istých aspektoch horšie ako úroveň šiestej triedy ale môže ísť o slengový slovník...
PříspěvekZaslal: po duben 08 2019, 11:51    Předmět: Citovat
Že se s tím rozčiluješ. Mrkni se na počet přispěvků a pochopíš. Wink
Heno
PříspěvekZaslal: po duben 08 2019, 11:56    Předmět: Citovat
Ja sa nudím Smile
danhard
Založen: Mar 05, 2007
PříspěvekZaslal: po duben 08 2019, 12:34    Předmět: Citovat
Ale když mu no go 5V sekce, tak bych hledal chybu tam Smile
