Založen: Oct 30, 2006 Příspěvky: 2310 Bydliště: Poblíž Zlína
Zaslal: pá prosinec 09 2022, 13:01 Předmět: St Link/v2 Update
Já když jsem si chtěl updatovat St Link/v2 tak mi avast zabránil co s tým ? díky
kód:
Error in final launch sequence:
Failed to start GDB server
Error launching GDB server. Session terminated
Cannot run program "C:\ST\STM32CubeIDE_1.11.0\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.win32_2.0.400.202209281104\tools\bin\ST-LINK_gdbserver.exe": Launching failed
Zaslal: ne prosinec 11 2022, 12:43 Předmět:
Neodolal jsem a nainstaloval jsem si na notebook na kterém je WIN7 STlink v2 ,zajímavé je že kit stm32vldiscovery funguje ale stm32f0discovery ne
kód:
12:05:28 : No ST-LINK detected
12:05:40 : Disconnected from device.
12:05:46 : No ST-LINK detected
12:07:22 : ST-LINK SN : ST-Link/V1_on_F:
12:07:22 : V1J13S0
12:07:22 : Connected via SWD.
12:07:22 : Connection mode : Normal.
12:07:22 : Debug in Low Power mode enabled.
12:07:22 : Device ID:0x420
12:07:22 : Device flash Size : 128KBytes
12:07:22 : Device family :STM32F100xx Low/Medium density Value Line
12:07:53 : Disconnected from device.
12:09:04 : Can not connect to target!
Please select "Connect Under Reset" mode from Target->Settings menu and try again.
If you're trying to connect to a low frequency application , please select a lower SWD Frequency mode from Target->Settings menu.
12:09:12 : Can't reset the core
12:09:45 : ST-LINK SN : ST-Link/V1_on_F:
12:09:45 : V1J13S0
12:09:45 : Connected via SWD.
12:09:45 : Connection mode : Normal.
12:09:45 : Debug in Low Power mode enabled.
12:09:45 : Device ID:0x420
12:09:45 : Device flash Size : 128KBytes
12:09:45 : Device family :STM32F100xx Low/Medium density Value Line
12:10:49 : File saved as C:\Users\Documents\blink.bin
12:11:00 : Disconnected from device.
12:11:31 : [blink.bin] opened successfully.
12:11:31 : [blink.bin] checksum : 0x00072AA4
12:11:42 : ST-LINK SN : ST-Link/V1_on_F:
12:11:42 : V1J13S0
12:11:42 : Connected via SWD.
12:11:42 : Connection mode : Normal.
12:11:42 : Debug in Low Power mode enabled.
12:11:42 : Device ID:0x420
12:11:42 : Device flash Size : 128KBytes
12:11:42 : Device family :STM32F100xx Low/Medium density Value Line
12:11:49 : Memory programmed in 0s and 531ms.
12:11:49 : Verification...OK
12:11:49 : Programmed memory Checksum: 0x00072AA4
12:12:05 : Disconnected from device.
12:12:08 : ST-LINK SN : ST-Link/V1_on_F:
12:12:08 : V1J13S0
12:12:08 : Connected via SWD.
12:12:08 : Connection mode : Normal.
12:12:08 : Debug in Low Power mode enabled.
12:12:09 : Device ID:0x420
12:12:09 : Device flash Size : 128KBytes
12:12:09 : Device family :STM32F100xx Low/Medium density Value Line
12:12:51 : Disconnected from device.
12:13:54 : Can not connect to target!
12:13:56 : Can't reset the core
12:14:14 : Disconnected from device.
12:14:36 : ST-LINK SN : ST-Link/V1_on_F:
12:14:36 : V1J13S0
12:14:36 : Connected via SWD.
12:14:36 : Connection mode : Normal.
12:14:36 : Debug in Low Power mode enabled.
12:14:36 : Device ID:0x420
12:14:36 : Device flash Size : 128KBytes
12:14:36 : Device family :STM32F100xx Low/Medium density Value Line
12:15:08 : Disconnected from device.
12:16:24 : Can not connect to target!
12:16:48 : Can't reset the core
12:17:08 : Can not connect to target!
12:17:32 : Can't reset the core
12:18:17 : Can not connect to target!
12:18:20 : Can't reset the core
12:18:22 : Disconnected from device.
12:18:22 : Connection to device is lost: check power supply and debug connection.
12:18:22 : If the target is in low power mode, please enable "Debug in Low Power mode" option from Target->settings menu.
12:18:26 : Disconnected from device.
12:18:52 : Can not connect to target!
12:18:55 : Can't reset the core
12:19:04 : Disconnected from device.
12:19:21 : ST-LINK SN : ST-Link/V1_on_F:
12:19:21 : V1J13S0
12:19:21 : Connected via SWD.
12:19:21 : Connection mode : Normal.
12:19:21 : Debug in Low Power mode enabled.
12:19:21 : Device ID:0x420
12:19:21 : Device flash Size : 128KBytes
12:19:21 : Device family :STM32F100xx Low/Medium density Value Line
12:19:52 : Disconnected from device.
Píšeš že je to STlink v2, ale v tom výpisu je STlink v1. Co je pravda?
Podívej, jenom entuziasmus nestačí, je potřeba o tom všem něco vědět, a já mám pocit že se ondraN nemýlil, když napsal že jsi přecenil své schopnosti, to je jedna věc. Druhá věc, že jsi ani přes přímý dotaz nikde nepřiznal (ale ani nepopřel), jestli je to do školy. Měl bys přiznat barvu, protože to co vadí není škola, ale neupřímnost (a jiné vysvětlení proč od toho ani tak neustupuješ se stejně nenabízí). Je tu spousta ochotných lidí, ale nikdo z nich se nenechá houpat.
Tak jak?
Edit: Mimochodem, je to již sedmé vlákno, které jsi i přes upozornění založil k jedné a té samé věci.
Založen: Feb 25, 2008 Příspěvky: 18774 Bydliště: Rychnovsko
Zaslal: po prosinec 12 2022, 9:44 Předmět:
Inu mahony , jsi zde jen moment , tak nejspíš nevíš , že p.markoni je letitý pán , bastlíř a PC lama , jako já . Takže pokud chceš začít něco p.markonimu psát , je třeba si tuto realitu představit .
Když ten pán šetří informacemi, tak se toho pak neví víc než jen tohle (kdybych se aspoň neptal). Mimochodem, i ty se mýlíš, a navíc jsem byl ochoten pomoci i osobně, bydlím poměrně nedaleko, ale když se šetří informacemi (psal mi i SZ… Otázku, která končí dvěma vykřičníky jsem dostal poprvé v životě), tak si nebudu trhat žíly a ničit nervy, nejsme v mateřské škole (a ten čas taky nikde nekradu).
