DrayTek Vigor2110 - dokola sa restartuje
PříspěvekZaslal: čt červenec 11 2024, 18:31    Předmět: DrayTek Vigor2110 - dokola sa restartuje Citovat
Ethernetovy router DrayTek Vigor2110 prestal fungovat - zacne bootovat, ale hned sa restartuje. Elyty som vymenil - boli dobre, takze ziadna zmena. Tak som cez bootloader a TFTP preflashoval firmware - a stale sa to sprava rovnako. Vypis z konzoly:
kód:
ROM VER: 1.0.3
CFG 01
Read`
ROM VER: 1.0.3
CFG 01
Read EEPROMX
 X
 relocate_code start
 relocate code finish
 Go...
 IO_Port_Init!!
Detect existed devices!!Modes: __STDC__ 32-bit mwDWORD==(unsigned long)
mwROUNDALLOC==4 sizeof(mwData)==24 mwDataSize==24
statistics: now collecting on a line basis
============= Memwatch Auto Self Test =============
Normal Free...DETECTED
Double Free...DETECTED
NULL Free.....DETECTED
Wild Free.....DETECTED
Underflow.....DETECTED
Overflow......DETECTED
Unfree 1......DETECTED
Unfree 2......DETECTED
ALL TEST OK!
Please be assured that all test buffers have freed.
Slab kmalloc range:     [0x8088B838:0x80F8C837](size=7344127 bytes)
Linear malloc range:    [0x818A2C90:0x81EFF000](size=6669168 bytes)
 !!! Maxi malloc size =2076655000 (st=628b268, end=81eff000)!!!!
 init cpu_wait to r4k_wait()!!
 trap_init() doneTODO: chip version
 danube_setup() donemips_hpt_frequency:166666667
r4k_offset: 00196e6a(1666666)
Using 166.667 MHz high precision timer.
 c0_hpt_timer_init()..count=1803382456.
 time_init()...
 dma_init() done
 init_IRQ() partial done
 skb_init() doneCPU revision is: 00019641
 cpu_report() donePrimary instruction cache 16kB, physically tagged, 4-way, linesize 32 bytes.
Primary data cache 16kB, 4-way, linesize 32 bytes.
 cache_init() donePCI: Probing PCI hardwar~
ROM VER: 1.0.3
CFG 01
Toto sa opakuje dokola, vzdy to skonci presne na "PCI hardwar". PCI zariadenie tam ziadne nie je - je to verzia bez wifi. Je tam len CPU, RAM, flash a switch. Switch nie je odpaleny, vsetky porty funguju (po pripojeni kabla sa rozsvieti prislusna LED).
Napajanie na osciloskope OK. Skusal som aj pripojit 3,3V z lab. zdroja - bez zmeny.
Ostava uz asi len vadna RAM alebo samotny CPU? Je tam vraj VSC7501, ale je na nom nalepeny chadic.
 Velikost:  254.1 kB
 Zobrazeno:  28 krát
Mahoney
Založen: Oct 26, 2019
PříspěvekZaslal: pá červenec 12 2024, 8:12    Předmět: Citovat
Pravděpodobně vyhřátý. Jestli si s tím chceš hrát, místo originálního firmware naflashuj MemTest pro MIPS architekturu a nech to běžet minimálně 24 hodin (pokud poběží).
