Servisni menu SONY - audio
MartinM
Neregistrovaný
PříspěvekZaslal: so listopad 05 2005, 12:36    Předmět: Servisni menu SONY - audio Citovat
U televizoru SONY 32FQ70K od poloviny indikace zesileni zvuku se jiz dale zvuk nezesiluje. Nevite nekdo nahodou, co presne znamenaji nasledujici zkratky v servisnim menu audio M-N , M-D , M-S, ... Dekuji.
evzena
Založen: Jul 06, 2005
PříspěvekZaslal: ne listopad 06 2005, 19:29    Předmět: Citovat
Zkus tohle:Сервисные меню телевизоров SONY
В телевизорах SONY после входа в сервисное меню кроме информации о прошивке микропроцессора есть еще и командный код [ ТТ _ _ ] . Вводя вместо прочерков двузначные цифры можно поменять режимы телевизора.
Например: TT25 -> Переключение в BG-DK
TT00 Switch TT-- mode off TT01 Set picture level to maximum
TT02 Set picture level to minimum TT03 Set volume to 35%
TT04 Set volume to 50% TT05 Set volume to 65%
TT06 Set volume to 80% TT07
TT08 Shipping condition (Analog values are RESET to factory setting, Prog 1 is selected, TT-- mode switched off, Vol=35%) TT09 Dummy
TT10 No function TT11 Dummy
TT12 Text Picture Level Offset (Enable/Disable) TT13 Select Odd/Even field for Non-interlased teletext
TT14 Select Interlaced/Non-interlased teletext display TT15 Read factory setting from ROM to NVM - Reads Volume, Brightness, Picture, Hue, Sharpness and Colour values from ROM to the actual used values (Last Power Memory)
TT16 No function TT17 Enable/Disable Sharpness Operation
TT18 Enable/Disable Teletext Operation TT19 Enable/Disable NTSC Operation
TT20 No function TT21 Sub picture
TT22 Sub Colour (Pal/Secam Different Stores) TT23 Sub Brightness
TT24 Destination System BG/L TT25 Destination Systems BG/L
TT26 Destination Systems i TT27 Destination System I/T
TT28 Destination BG only TT29 Dummy
TT30 No function TT31-32 Dummy
TT33 Auto AGC Adjust TT34 Auto PLL Adjust
TT35-37 Dummy TT38 Enter G2 adjustement mode
TT39 Dummy TT40 No function
TT41 Re-initialise NVM TT42 Dummy
TT43 Re-initialise Geometry settings TT44-47 Dummy
TT48 Set NVM testbyte to 44h in NVM TT49 Erase NVM
TT50 No function
evzena
anonym
PříspěvekZaslal: ne listopad 06 2005, 19:41    Předmět: Citovat
Diky, mrknu na to.
