Založen: Dec 28, 2008 Příspěvky: 21 Bydliště: Savín
Zaslal: ne prosinec 28 2008, 21:12 Předmět:
Sendyx napsal(a):
Pšššt, přečte si to tajemník nějakého europoslance a co nevidět nejen, že nekoupíme žárovku, ale budem smět jen zapínat a vypínat v nule, do každého vypínače jeden procík, SSR a hrst součástek. Přece nechceš, aby výrobci elektroniky neměli co žrát
ježiš zas to tak neřeš, chtěl sem poradit jak zapojit vykonovo čast a furt slyšim že všecko je špatně a na nic, tak kde to vede:?
Zaslal: po prosinec 29 2008, 1:10 Předmět:
kód:
* IGBT Driver:
* An IGBT driver turns the output ON at the zero cross point and turns
* the output OFF part way through the cycle - this has really low
* EMI properties and is one of the few methods allowed for phase control
* in European countrys (i.e complies with EN55015 EMI standard).
* Other countries are following suit for example New Zealand and Austrailia
* are almost there (See AS/NZS 4051 and CISPR15 EMI Standards )
* This method of dimming is audibly quiet, does not require extra filter
* componets (If designed properly).It also has a better lamp life and can
* control a wider range of lamps than the TRIAC method of dimming.
* TRIAC Driver:
* A TRIAC driver turns the output OFF at the zero-cross and turns the
* output ON part way through the cycle - this has high EMI output and needs
* filter inducors etc. This has been the most popular method of phase
* control since it was first demonstraited in London in 1962. To make
* the TRIAC dimmer complient with modern EMI standards it requires
* carefully designed filter circuits using large Toroid Inductors
* and mains voltage AC rated capacitors.
* This is still the simplest method to do, and quite cheap, but not
* recommended for comercial designs any more.
* It also has a tendancy to reduce Lamp life, and creates alot of audiable
* noise in both the inductors and lamps.
Tak něco takovyho piše ten co to programoval přede mnou, tak sem podle teho usoudil, že to bude asi lepši a včil teda nevim co si o tym mám myslet. Taky nevim proč to rušeni bude podle něho menši podle vás větši, tak to vyzkošime, napichnem na osciloskop a uvidime co nám to hodi
Založen: Sep 10,
2004 Příspěvky: 19668 Bydliště: Jičín, Český ráj
Zaslal: po prosinec 29 2008, 8:53 Předmět:
Tak to by stálo za to, dát sem potom výsledky.
Asi záleží i na tom, jak rychle prvek spíná či rozpíná, na indukčnosti vedení před ním a za ním (energie magnetického pole se nemá v rozpojeném obvodu kde spotřebovat, tak vznikne napěťový impuls, viz zapalování zážehových motorů nebo blokující měniče). Takže není vyloučené, že rušení při vypínání v maximu bude větší problém potlačit, než rušení tyristorového či triakového spínače. To rušení totiž nedělá samotný spínač, ale přechodové jevy na zdroji, vedení a spotřebiči.
V každém případě by spínání s tranzistorem mělo být imunní proti známému blikání triakových stmívačů vlivem signálu HDO.
No, jsem zvědav.
Strana 3 z 3
