Manualni rizeni PWM
endthe
Založen: Mar 07, 2009
PříspěvekZaslal: st duben 01 2009, 2:27    Předmět: Manualni rizeni PWM Citovat
Napsal sem si funci na rizeni dvojice servomotoru HS 422
pouzity xtal = 14745600Hz
zapis je nasledujici:
kód:
int manual(void)
int natoceni1;
int natoceni2;
int prepocetH=90;
int prepocetL=90;
char info1[20];
char info2[20];
OCR3A=1500;
OCR3B=1500;
   clear_disp();
         sprintf(info1, "Servo 1:  %d°",prepocetH);
         sprintf(info2, "Servo 2:  %d°",prepocetL);
         put_string_xy(0, 0, info1);
         cursor_disp_ctrl(0x04);
         put_string_xy(0, 1, info2);
key = 0;
   while (key == 0);
   // display button name
   while(1) {
      if (key != 0) {
         switch (key) {
            case 0x11 : {prepocetH+=1;}; break;      // 1
            case 0x12 : {prepocetH+=10;}; break;      // 2
            case 0x14 : {prepocetH+=100;}; break;      // 3
            case 0x21 : {prepocetH-=1;}; break;      // 4
            case 0x22 : {prepocetH-=10;}; break;      // 5
            case 0x24 : {prepocetH-=100;}; break;      // 6
            case 0x41 : {prepocetL+=1;}; break;      // 7
            case 0x42 : {prepocetL+=10;}; break;      // 8
            case 0x44 : {prepocetL+=100;}; break;      // 9
            case 0x82 : {prepocetL-=10;}; break;      // 0
            case 0x81 : {prepocetL-=1;}; break;      // *
            case 0x84 : {prepocetL-=100;}; break;      // #
            case 0x18 :return(1);break;                   // ESC
         //pipani
         key = 0;
         beep(200, 10);
         if(prepocetH>=180) prepocetH=180;
         if(prepocetL>=180) prepocetL=180;
         if(prepocetH<=0) prepocetH=0;
         if(prepocetL<=0) prepocetL=0;
         //prepocet uhlu na ciselnou hodnotu OCR3A
         natoceni1=1000+(prepocetH*5,5);
         natoceni2=1000+(prepocetL*5,5);
         //vypis hodnot
         OCR3A=natoceni1;
         OCR3B=natoceni2;
         clear_disp();
         PWM();
int PWM(void)
DDRE = 0x18; //povoleni portu PE3 a PE4 jako vystup PWM (OC3A a OC3B)
//Pouzita preddelicka 8 (prescaler)
ICR3=36864; //nastavenim ICR3=36864 dosahnu f=50Hz f=fxtal/N*TOP  N=8 ICR1=TOP
TCCR3A|=(0<<COM3A0)|(1<<COM3A1)|(0<<COM3B0)|(1<<COM3B1)|(1<<WGM31)|(0<<WGM30); // fazove korigovana PWM (0<<WGM31)|(1<<WGM30)
//######################PWM PRO SERVO 2 ################################
TCCR3B|=(0<<ICNC3)|(0<<ICES3)|(1<<WGM33)|(1<<WGM32)|(0<<CS32)|(1<<CS31)|(0<<CS30);
Ale nejak mi nechce jit
kód:
         //vypis hodnot
         OCR3A=natoceni1;
         OCR3B=natoceni2;
a tim padem mi nechtej jit serva respektive chcou se hybat ale snazi se najet nekam kam nemuzou co s tim?
Naposledy upravil endthe dne st duben 01 2009, 17:11, celkově upraveno 1 krát.
Ragnol
Založen: Nov 09, 2005
PříspěvekZaslal: st duben 01 2009, 7:56    Předmět: Citovat
místo toho zapiš
//vypis hodnot
OCR3A=natoceni1;
OCR3B=natoceni2;
hlavně nejen že jsem ti ušetřil dvě proměnný ale hlavně se v C desetinný čárka píše tečkou a ne čárkou ... proto to blbě počítalo.
OCR3A=1000+(prepocetH*5.5);
OCR3B=1000+(prepocetL*5.5);
endthe
PříspěvekZaslal: st duben 01 2009, 13:36    Předmět: Citovat
tak sem to opravil ale stejne mi t porad nechce tocit servem poradi nekdo?
Andrea
Založen: Sep 07, 2007
PříspěvekZaslal: st duben 01 2009, 15:36    Předmět: Citovat
Odkud spadla ta čísla, 1000, které přičítáš a 5.5, kterým násobíš?
endthe
PříspěvekZaslal: st duben 01 2009, 15:54    Předmět: Citovat
Andrea napsal(a):
to je z vypoctu pokud 1500 je 90° , 1000 je 0° a 2000 je 180° potom to vychazi na
OCR3A=1000+(prepocetH*5.555555556);
OCR3B=1000+(prepocetL*5.555555556);
a to sedi je to pocitane pomoci trojclenky Smile
mas snad jiny zpusob vypoctu delky pulzu z natoceni serva (podotykam zadavani je pomoci natoceni o 0° do 180° takze je to nutne prepocitat)
Andrea
PříspěvekZaslal: st duben 01 2009, 16:01    Předmět: Citovat
endthe napsal(a):
Ale jak jsi přišel na to, že 1000 je 0° a 2000 je 180°?
endthe
PříspěvekZaslal: st duben 01 2009, 16:06    Předmět: Citovat
Andrea napsal(a):
endthe napsal(a):
no pouzivam serva HS 422
a 1ms je leva krajni poloha oznacena 0°
2ms je prava krajni poloha oznacena 180°
jinak to definovani ma byt ze kdyz dam 1000 tak delka bude 1ms
delal sem to podle tohoto a upravoval na megu128
http://winavr.scienceprog.com/example-avr-projects/servo-motor-control-using-avr.html
Andrea
PříspěvekZaslal: st duben 01 2009, 16:11    Předmět: Citovat
endthe napsal(a):
Když je 36864 = 20ms, tak jak může být 1000 = 1ms a 2000 = 2ms, to mi prosím vysvětli (asi někdo neumí přemýšlet a počítat a jen tupě opisuje cizí programy).
endthe
PříspěvekZaslal: st duben 01 2009, 16:19    Předmět: Citovat
Andrea napsal(a):
endthe napsal(a):
pokud se nepletu tak ICR3 je tech 36864 a to je pri tom pouzitem krystalu 50Hz
no dobre pokud to je tak tak to 1000 a 2000 nemuze byt
musi to byt 1843.2 pro 1ms 2764.8 pro 1,5ms a 3686.4 pro 2ms
tudiz ten prepocet by mel vypadat takto pokud sem dobre pocital:
kód:
         OCR3A=1843.8+(prepocetH*10.24);
         OCR3B=1843.8+(prepocetL*10.24);
endthe
PříspěvekZaslal: st duben 01 2009, 16:57    Předmět: Citovat
ale stejne mam pocit ze se ty dve PWM ovlivnuji navzajem da se to nejak poresit?
jinak serva napajim externe
Naposledy upravil endthe dne st duben 01 2009, 17:14, celkově upraveno 1 krát.
Andrea
PříspěvekZaslal: st duben 01 2009, 17:08    Předmět: Citovat
Pokud nemáš chybu v programu, tak se ty PWM nemůžou ovlivňovat. Máš dobře blokované napájení, alespoň 470uF u každého serva?
A proč v programu po každém stisku klávesy znovu inicializuješ Timer3 a proč v té inicializaci děláš příkaz ICR1=TOP?
endthe
PříspěvekZaslal: st duben 01 2009, 17:13    Předmět: Citovat
Andrea napsal(a):
no to ICR3 tam je traba aby PWM melo frekvenci 50Hz pokud sem to dobre pochopil
jinak jak mam teda delat to PWM abych po kazdem stisku zmenil natoceni serva mam nechat poouze zmenu OCR3A a OCR3B a ten Timer3 inicializovat poze v mainu kde odskakuju z menu do teto fce?
serva napajim externe a u kazdeho mam 1000uF
Andrea
PříspěvekZaslal: st duben 01 2009, 17:26    Předmět: Citovat
endthe napsal(a):
Jistě, stačí tu inicializaci provést na začátku, pak už jen po stisku klávesy měnit OCR3A a B.
endthe
PříspěvekZaslal: st duben 01 2009, 17:35    Předmět: Citovat
Andrea napsal(a):
endthe napsal(a):
dobre jdu to zkusit. Diky Andrejko
P.S.: jinak jakym zdrojem doporucujes napajet ty serva
Andrea
PříspěvekZaslal: st duben 01 2009, 18:13    Předmět: Citovat
endthe napsal(a):
Moc zkušeností s nima nemám, takže na nějaké doporučení si netroufám, ale na 4 tužkovky běhaly a na zdroj 5V/2A taky.
