Založen: Feb 04, 2010 Příspěvky: 775 Bydliště: Karlovy Vary
Zaslal: pá únor 11 2011, 15:29 Předmět: Sony KV-29FX66K
U televizoru Sony KV-29FX66K bliká stand-by LED po zapnutí 5x.
Stanese, že nejde zapnout do normálního stavu, ale jen někdy.
našli jsme: The fact that the problem seems to appear only on scart or S-video inputs could be due to the fact that the video levels are different on external inputs and the internal tuner.
Error 5 is displayed when there is insufficient beam current detected during the automatic white-balancing procedure. Insufficient beam current occurs when the picture tube got at the end of its lifespan.
You can check in the TV's error monitor the number of hours the set has operated. If it is more than 20.000, then the diagnose of a worn-out picture tube is very plausible. Another thing you can check is the focus of the picture. When the tube is bad, the sharpness of the picture in the corners is significant poorer as in the center of the screen.
The error monitor could be displayed by the following procedure: Put the TV in standby. Then push the next four keys in a rather swift sequence: i+ , 5, VOLUME+, TV. (i+ is the key for display on screen, TV is the key with the blank picture tube symbol you use to revert to normal picture after viewing teletext.. The set will power up now, displaying 'TT--' in the upper right corner of the screen. Then enter 99 (and NOTHING ELSE!) to display the error monitor. There is a list of registrated errors (in your case there will be an amount behind E05) and at the bottom of the screen the operating hours are displayed. After this, you can press the menu button and enter 00. This will leave service mode. BE AWARE THAT YOU ENTER ONLY 99 OR 00 when TT-- is on the screen. Other input or use of the MENU button could lead to a situation you cannot revert from by yourself because a reload of the sets memory is necessary then.
Tedy návod na zobrazení servisního modu, bohužel, právě uvedené potíže nedovolí televizor restartovat a údaje o chybě resp. délky doby provozu přístroje ukázat.
tuto tv doma nemám je to jen rada na dálku.
Nesetkal se někdo z vás s touto závadou a jak ste ji řešili. _________________ píďa
IKR error pokud si dobře pamatuju, dávaly Sony TV v případě, že byla obrazovka na odchodu, někdy pomohlo trošku zvednout UG2. Jinak samozřejmě bych prověřil Soňáckou klasiku, studené spoje, to nebude na škodu.
