Zaslal: út březen 15 2011, 19:49 Předmět: TESLA AZK 182 Bass Combo
Hello, guys . Greetings from Russia !
I came here to ask you for help, because I am in despair to find a scheme of Czech bass combo TESLA AZK 182 (B100-115). I have one of those combos, but it doesn't work well, some problems with parametric equalizer.
It is very hard to me to find a scheme, because i don't know Czech and because most of the searching results lead me to TESLA AZK 182, which is a popular tape recorder, but no information about bass combo.
May be, you could give me an advice, where can i find such a scheme? May be you know some Czech Bass Guitar Forums or other Electronic Forums, where I could continue my search?
Thanks .
Excuse my English
Naposledy upravil Yaroslav1988 dne st duben 06 2011, 16:32, celkově upraveno 2 krát.
thanks, but the main problems of mine connected with preamp (parametric and graphic equalizer on single printed circuit board ), not the amplifier itself
yesterday i found a lot of schematics of my amp and also printed circuit
but none of them contains preamp section (high and low inputs, volume, compression, EQ1: bass, mid, treb. EQ2: 60Hz 150Hz 400Hz 1kHz 2.7kHz)
