TDA9860 chyba v datasheet
edoedo20
Založen: Nov 10, 2010
PříspěvekZaslal: pá srpen 24 2012, 17:06    Předmět: TDA9860 chyba v datasheet Citovat
Mozno niekomu pomozem informaciou o chybe v datasheet TDA9860. Jedna sa o univerzalny audio procesor ovladany prostrednictvom I2C-zbernice.
Format I2C-bus podla katalogu:
S / SLAVE ADDRESS / A / SUBADDRESS / A / DATA / P
Format I2C-bus podla mna, teda funkcny:
S / SLAVE ADDRESS / A / SUBADDRESS / A / DATA / A / P
S = start condition
SLAVE ADDRESS = 1000 0000 (V25 = LOW) or 1000 0010 (V25 = HIGH)
A = acknowledge, generated by the slave or by the master
SUBADDRESS = subaddress byte, see Table 1
DATA = data byte, see Table 1
P = stop condition
