Ročníky urob si sám
NEONI
Založen: Feb 11, 2007
PříspěvekZaslal: st březen 07 2007, 12:48    Předmět: Ročníky urob si sám Citovat
Nevie niekto z vas kde by som mohol stiahnut z netu rocniky casupisu urob si sam ?? Je to vobec v elektronickej podobe??
miroja
Založen: Feb 28, 2006
PříspěvekZaslal: st březen 07 2007, 14:33    Předmět: Citovat
Na zaciatok skus toto (bez zaruky):
kód:
Rocnik2002:
http://rapidshare.com/files/7652610/USS_2002-01.pdf
http://rapidshare.com/files/7652611/USS_2002-02.pdf
http://rapidshare.com/files/7654576/USS_2002-03.pdf
http://rapidshare.com/files/7654577/USS_2002-04.pdf
http://rapidshare.com/files/7654578/USS_2000-05.pdf
http://rapidshare.com/files/7654580/USS_2002-06.pdf
http://rapidshare.com/files/7656495/USS_2002-07.pdf
http://rapidshare.com/files/7656497/USS_2002-08.pdf
http://rapidshare.com/files/7656498/USS_2002-09.pdf
http://rapidshare.com/files/7658087/USS_2002-10.pdf
http://rapidshare.com/files/7658088/USS_2002-11.pdf
http://rapidshare.com/files/7658089/USS_2002-12.pdf
Rocník 2003:
http://rapidshare.com/files/7662836/USS_2003-01.pdf
http://rapidshare.com/files/7662837/USS_2003-02.pdf
http://rapidshare.com/files/7662838/USS_2003-03.pdf
http://rapidshare.com/files/7662839/USS_2003-04.pdf
http://rapidshare.com/files/7663933/USS_2003-05.pdf
http://rapidshare.com/files/7663934/USS_2003-06.pdf
http://rapidshare.com/files/7663936/USS_2003-07.pdf
http://rapidshare.com/files/7663937/USS_2003-08.pdf
http://rapidshare.com/files/7666242/USS_2003-09.pdf
http://rapidshare.com/files/7666244/USS_2003-10.pdf
http://rapidshare.com/files/7666245/USS_2003-11.pdf
http://rapidshare.com/files/7666246/USS_2003-12.pdf
Rocník 2004:
http://rapidshare.com/files/7697834/USS_2004-01.pdf
http://rapidshare.com/files/7697835/USS_2004-02.pdf
http://rapidshare.com/files/7697836/USS_2004-03.pdf
http://rapidshare.com/files/7697837/USS_2004-04.pdf
http://rapidshare.com/files/7699304/USS_2004-05.pdf
http://rapidshare.com/files/7699305/USS_2004-06.pdf
http://rapidshare.com/files/7699306/USS_2004-07.pdf
http://rapidshare.com/files/7699307/USS_2004-08.pdf
http://rapidshare.com/files/7665076/USS_2004-09.pdf
http://rapidshare.com/files/7665077/USS_2004-10.pdf
http://rapidshare.com/files/7665078/USS_2004-11.pdf
http://rapidshare.com/files/7665079/USS_2004-12.pdf
Rocník 2005:
http://rapidshare.com/files/7700416/USS_2005-01.pdf
http://rapidshare.com/files/7700417/USS_2005-02.pdf
http://rapidshare.com/files/7700418/USS_2005-03.pdf
http://rapidshare.com/files/7700419/USS_2005-04.pdf
http://rapidshare.com/files/7701663/USS_2005-05.pdf
http://rapidshare.com/files/7701665/USS_2005-06.pdf
http://rapidshare.com/files/7701666/USS_2005-07.pdf
http://rapidshare.com/files/7701667/USS_2005-08.pdf
http://rapidshare.com/files/7702949/USS_2005-09.pdf
http://rapidshare.com/files/7702950/USS_2005-10.pdf
http://rapidshare.com/files/7702951/USS_2005-11.pdf
http://rapidshare.com/files/7702952/USS_2005-12.pdf
Radix
Založen: Nov 14, 2006
PříspěvekZaslal: st březen 07 2007, 15:36    Předmět: Citovat
V elektronické podobě to existuje 1970 - 2005.
Naposledy upravil Radix dne st březen 07 2007, 16:48, celkově upraveno 1 krát.
ypsi
Založen: Oct 12, 2005
PříspěvekZaslal: st březen 07 2007, 16:41    Předmět: Citovat
Wow, a to fakt? Shocked
Radix
PříspěvekZaslal: st březen 07 2007, 16:54    Předmět: Citovat
Dám je výměnou za CD Amatérského rádia.
NEONI
PříspěvekZaslal: st březen 07 2007, 19:18    Předmět: Citovat
CD AR mam vsetky od 87 dole
Radix
PříspěvekZaslal: st březen 07 2007, 20:23    Předmět: Citovat
Škoda, že jsi z ciziny.
vombat
Založen: Aug 18, 2005
PříspěvekZaslal: čt březen 08 2007, 20:20    Předmět: Citovat
Mám CD AR od 96, dále mám RADIO od 1970-2004 - ruské a další podobné ruské časopisy.
Radix
PříspěvekZaslal: čt březen 08 2007, 21:18    Předmět: Citovat
A chceš uskutečnit tu výměnu? USS mám 1970-2005 na pěti CD.
galjo
Založen: Jul 15, 2005
PříspěvekZaslal: čt březen 08 2007, 21:49    Předmět: Citovat
Radix napsal(a):
Neni problém s poštou. Pri troche dôvery sa dá poslať normálnou poštou.. Ja to už robím roky... Peniaze v tmavej obálke alebo vbehnem na Hrozenkov alebo Strání a poukážku na väčšiu sumu...
Raptor181
Moderátor
Založen: Jan 01, 2004
PříspěvekZaslal: po březen 12 2007, 7:37    Předmět: Citovat
Tato tema je o Urob Si Sam a nie amaterskom radii...
Tem na Ar je tu dost a aj linkov na ne.
Čo neubrzdíš, to neukecáš..PC šťoural
PotleskSmile
Zobrazit informace o autorovi Odeslat soukromou zprávu Odeslat e-mail MSN Messenger
galjo
PříspěvekZaslal: út březen 13 2007, 12:03    Předmět: Citovat
Pre - miroja v ročníku 2002 je zamenené číslo USS_2000-05. podívaj sa po čísle USS_2002-05. a skus ho nahodiť.. Vdaka
