Flex kabel, potřebuji poradit
makkkb
Založen: Jul 26, 2014
PříspěvekZaslal: so červenec 26 2014, 9:03    Předmět: Flex kabel, potřebuji poradit Citovat
Zdravím, nedávno jsem si koupil nové auto, ve kterém bylo 1din rádio s vysouvací obrazovkou, ale nejde mi obraz. Majitel říkal, že je to tou flex páskou, ale nevím značku toho rádia, ale našel jsem ho na internetu tak sem přidám všechny údaje co tam píší a snad se něco najde.
7 Inch 1 DIN Car DVD Player With Detachable Panel (JD-7101S)
Product Detail
Basic Info
Model NO.: JD-7101S Certification: RoHS Voltage: DV12V Export Markets: Global
Additional Info
Origin: China
Product Description
Brief Feature:
1) 7 inch touch screen car DVD player
2) Digital screen 800X480 high resolution
3) Picture in Picture interface and 3D menu
4) Detachable panel and swivel screen
5) support USB, SD/MMC/MX, TF card
6) Built in AM, FM, Analog TV, bluetooth, iPod, RDS, GPS
7) 4X50W, Dual-zone
Cool Support steering wheel control
9) DVB-T is optional
Technical Specifications:
Model No.: JD-7101S
Screen Size: 7 inch ( 16: 9 TFT-LCD )
Touch Screen: YES
Screen Brand: AUO ( made in Taiwan )
High Resolution: 800 X 3(RGB) X 480 digital screen
DVD Specifications:
Compatible with: DVD/SVCD/DVCD/DVD-R/DVD-RW/VCD/CD/CD-R/CD-RW/MP3/WMA/JPG/MPEG1/2/4, DIVX6.0
DVD loader: FORYOU ( made in China) / Panasonic ( made in Japan)
DVD Lens: Hitachi ( made in Japan)
Button backlight: With Red/Blue illumination
Built in GPS Navigation: Support TOMTOM, IGO8, Route66 ect.
Dual Zone function: YES (Listen to music while GPS navigation)
Picture in Picture ( PIP): 4 screen coner position, Minimize/maximize/Middle window
Analog TV: Built in, PAL/NTSC/SECAM System
Digital TV: DVB-T/ATSC-H/ISDB Optional ( 170MHz-950Hz )
Bluetooth: Handsfree with call record, support A2DP
Radio: FM/AM/RDS receiver
USB port: With USB cable (for Music/movie)
Shock Resistance: YES
Built-in DOLBY: YES
Game: YES
SD Card slot: 1 SD card slot for Music/movie, 1 SD card slot for GPS map
Built-in RAM: YES
Amplifier: 4X50 Watts
Video output/input: 1-channel NAVI/1-channel CDC/1-channel AUX in, 1-channel video out
Audio output/input: 2-channel AUX LR/2-channel CDC LR in;
6-channel: FRONT OUT R/FRONT OUT L/REAR OUT R/REAR OUT SUR L/SUR R
TV signal input: 2-TV antenna input port
GPS Specification:
Operation system Windows CE5.0
Support map: IGO/ROUTE66/TOMTOM/NAVTEQ ect.
CPU: Samsung S2C2440 Processor
Main Frequency: 400MHz
EMS Memory: 64MB SDRAM
Storage device: 64MB
Display output: CVBS+S-VIDEO/RGB output.
Support Audio type: MP3/PCM/WMA
Support Video Type: ASF/AVI /WMV /DIVX
Chipset: Samsung
Power supply: DC12V 3A Output
Consumption: 4.5W(12V/360mA), Normal power consumption 3W(12V/250mA).
Temperature: Operation temperature -20 to 70 degree
Product Dimension 180mm X 178mm X 50mm
Product N. W: 3.25KG
 Soubor:  IMG_0910.JPG
 Velikost:  254.04 kB
 Staženo:  151 krát
