A můžeš prosím poradit jak? Program běží na arduinu.
kód:
#include <Time.h>
#include <Wire.h>
#include <DS1307RTC.h> // a basic DS1307 library that returns time as a time_t
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 13;
int j = 0; int i = 0; int h = 0;
int g = 0; int k = 0; int l = 0;
int hours = 0;
int minutes = 0;
int seconds = 0;
//holders for infromation you're going to pass to shifting function
byte dataONE;
byte dataTWO;
byte dataTRE;
byte dataFOUR;
byte dataFIVE;
byte dataSIX;
byte dataArray[10];
byte dataArrayd[10]; //dot on
void setup() {
//set pins to output because they are addressed in the main loop
pinMode(latchPin, OUTPUT);
pinMode(16, OUTPUT); //RTC on arduino GND
digitalWrite(16, LOW); //RTC on arduino GND
pinMode(17, OUTPUT); //RTC on arduino VCC
digitalWrite(17, HIGH); //RTC on arduino VCC
Serial.begin(9600);
setSyncProvider(RTC.get); // the function to get the time from the RTC
Wire.begin();
//Arduino doesn't seem to have a way to write binary straight into the code
//so these values are in HEX. Decimal would have been fine, too.
dataArray[0] = 0x3F;
dataArray[1] = 0x06;
dataArray[2] = 0x5B;
dataArray[3] = 0x4F;
dataArray[4] = 0x66;
dataArray[5] = 0x6D;
dataArray[6] = 0x7D;
dataArray[7] = 0x07;
dataArray[8] = 0x7F;
dataArray[9] = 0x6F;
//with dot on
dataArrayd[0] = 0xBF;
dataArrayd[1] = 0x86;
dataArrayd[2] = 0xDB;
dataArrayd[3] = 0xcF;
dataArrayd[4] = 0xE6;
dataArrayd[5] = 0xED;
dataArrayd[6] = 0xFD;
dataArrayd[7] = 0x87;
dataArrayd[8] = 0xFF;
dataArrayd[9] = 0xEF;
// digital clock display of the time
Serial.print(hour());
Serial.print(':');
Serial.print(minute());
Serial.print(':');
Serial.print(second());
Serial.println();
// Serial.print(now.hour()); // uncomment to debug
// Serial.print(':'); // uncomment to debug
// Serial.print(now.minute()); // uncomment to debug
// Serial.println(now.second()); // uncomment to debug
j = seconds % 10;
i = seconds / 10;
h = minutes % 10;
g = minutes / 10;
k = hours % 10;
l = hours / 10;
//load the light sequence you want from array
dataSIX = dataArray[j];
dataFIVE = dataArray[i];
dataFOUR = dataArrayd[h];
dataTRE = dataArray[g];
dataTWO = dataArrayd[k];
dataONE = dataArray[l];
digitalWrite(latchPin, 0);
//move 'em out
shiftOut(dataPin, clockPin, dataSIX);
shiftOut(dataPin, clockPin, dataFIVE);
shiftOut(dataPin, clockPin, dataFOUR);
shiftOut(dataPin, clockPin, dataTRE);
shiftOut(dataPin, clockPin, dataTWO);
shiftOut(dataPin, clockPin, dataONE);
//return the latch pin high to signal chip that it
//no longer needs to listen for information
digitalWrite(latchPin, 1);
delay(500);
// the heart of the program
void shiftOut(int myDataPin, int myClockPin, byte myDataOut) {
// This shifts 8 bits out MSB first,
//on the rising edge of the clock,
//clock idles low
//internal function setup
int i=0;
int pinState;
pinMode(myClockPin, OUTPUT);
pinMode(myDataPin, OUTPUT);
//clear everything out just in case to
//prepare shift register for bit shifting
digitalWrite(myDataPin, 0);
digitalWrite(myClockPin, 0);
//for each bit in the byte myDataOuti?1
//NOTICE THAT WE ARE COUNTING DOWN in our for loop
//This means that %00000001 or "1" will go through such
//that it will be pin Q0 that lights.
for (i=7; i>=0; i--) {
//if the value passed to myDataOut and a bitmask result
// true then... so if we are at i=6 and our value is
// %11010100 it would the code compares it to %01000000
// and proceeds to set pinState to 1.
if ( myDataOut & (1<<i) ) {
pinState= 1;
else {
pinState= 0;
//Sets the pin to HIGH or LOW depending on pinState
digitalWrite(myDataPin, pinState);
//register shifts bits on upstroke of clock pin
digitalWrite(myClockPin, 1);
//zero the data pin after shift to prevent bleed through
