Založen: Feb 14, 2005 Příspěvky: 9090 Bydliště: Brno (JN89GF)
Zaslal: st květen 18 2016, 10:21 Předmět:
Nojo, ale to tam budou i všechny šmírovací aktualizace, který jsem zakazoval. Škoda, že to není jen balík vyloženě bezpečnostních aktualizací.
Skoro aktuální seznam:
kód:
KB2882822 update for adding itracerelogger interface support
KB2902907 description not available, update was pulled by microsoft
KB2922324 description not available, update was pulled by microsoft
KB2952664 Compatibility update for upgrading Windows 7
KB2977759 update for windows 7 rtm
KB2990214 Update that enables you to upgrade from Windows 7 to a later version of Windows
KB3012973 upgrade to windows 10
KB3014460 update for windows insider preview / upgrade to windows 10
KB3015249 update that adds telemetry points to consent.exe in Windows 8.1 and Windows 7
KB3021917 Update to Windows 7 SP1 for performance improvements
KB3022345 Update for customer experience and diagnostic telemetry
KB3035583 Update installs Get Windows 10 app in Windows 8.1 and Windows 7 SP1
KB3042058 update for cipher suite priority order (contains winlogon spying elements)
KB3046480 update for migrating .net when upgrading to later version of windows
KB3050265 update for windows update client for windows 7 june 2015
KB3064683 update for windows 8.1 oobe modifications to reserve windows 10
KB3065987 update for windows update client for windows 7 and windows server 2008 r2 july 2015
KB3068708 Update for customer experience and diagnostic telemetry
KB3072318 update for windows 8.1 oobe modifications to reserve windows 10
KB3074677 compatibility update for upgrading to windows 10
KB3075249 update that adds telemetry points to consent.exe in windows 8.1 and windows 7
KB3075851 update for windows update client for windows 7 and windows server 2008 r2 august 2015
KB3080149 update for customer experience and diagnostic telemetry
KB3081437 august 18, 2015, compatibility update for upgrading to windows 10
KB3081454 september 8, 2015, compatibility update for upgrading to windows 10
KB3081954 update for work folders improvements in windows 7 sp1 (contains telemetry elements)
KB3083324 update for windows update client for windows 7 and windows server 2008 r2 september 2015
KB3083710 update for windows update client for windows 7 and windows server 2008 r2 october 2015
KB3086255 september 8, 2015, security update for the graphics component in windows (breaks safedisc)
KB3088195 october 13, 2015, security update for windows kernel (reported to contain a keylogger)
KB3090045 windows update for reserved devices in windows 8.1 or windows 7 sp1 (windows 10 upgrade elements)
KB3093983 security update for internet explorer: october 13, 2015 (ie spying elements)
KB3102810 windows 10 upgrade elements
KB3102812 windows 10 upgrade elements
KB3112343 update for windows update client for windows 7 and windows server 2008 r2 december 2015
KB3123862 updated capabilities to upgrade windows 8.1 and windows 7
KB3135445 windows update client for windows 7 and windows server 2008 r2: february 2016
KB971033 Description of the update for Windows Activation Technologies
Stáhni si co potřebuješ pomocí Wsusoffline, vyloučíš co nechceš a pomocí Nlite to naintegruješ do instalačního média. Takových integrátorů je víc... _________________ Nebojte se skloňovat (i cizí slova).
Založen: Aug 02, 2009 Příspěvky: 1388 Bydliště: Praha
Zaslal: st květen 18 2016, 13:10 Předmět:
Standa99 napsal(a):
To si piš, že tam budou
Jo, to by me taky zajimalo. Zatim to jen stahuju, zkusim to rozbalit. Pokud tam bude nekde zakopany nejaky seznam, z kterych KBcek je to seskladane, tak by to slo snadno dohledat, jesi to obsahuje i ty zname smiraky. Jinak ja jednou za cas postahuju MS security update DVD ISO image a tam si vyzobu co potrebuju (zajimaji me hlavne updaty pro XPE, tech uz je ale celkem po malu...)
@RAyeR: Sedmičky už dlouho nepoužívám, ale když jsem potřeboval, tak jsem si vždy stáhl tzv. Simplix Pack z MDL (každý měsíc nový). Nevím, jestli tam budou všechny updaty, ale asi jo. Navíc k tomu jdou stáhnout i baťáky, kterými to jde rovnou integrovat do WIM. _________________ .
Ať žije zdejší FOSILOVNA
Jo, dobra , ale prej pak este vyskoci jedno okno, kde to jde nejak zrusit. Stejne snad kazdej normalni uzivatel ve W7 ty automaticky aktualizace uz davno uplne zakazal...
Zaslal: st květen 18 2016, 15:13 Předmět:
Standa99 napsal(a):
V pohode, ja je zas este ani pouzivat nezacal , takze spis me to zajima akademicky nebo kdybych to nahodou instaloval nekomu jinemu...
Založen: Jan 12, 2009 Příspěvky: 7131 Bydliště: Plzeňsko
Zaslal: st květen 18 2016, 16:46 Předmět:
Stát se to mě, tak vypnu počítač, vyjmu harddisk, zapojím místo něj klon se zálohou, zanadávám, a budu spokojený, že používám klonování disků.
Bodejť by "počet uživatelů" stabilně nerostl, když se instalujou bez jejich vůle. _________________ Sháním hasičák s CO2 "sněhový", raději funkční.
(Nemusí mít platnou revizi.)
Zaslal: st květen 18 2016, 17:39 Předmět:
Kompletni zalohu systemu pouzivam taky, ale nemusim kuli tomu menit disk, jen pri startu nabootuju jiny OS, zkopiruju cca 850MB adresare windows, to je na SSD par vterin a za minutu uz mam zpatky nabootovanou predchozi funkcni zalohu U sedmicek by tech ~10GB balastu trvalo o neco dyl no...
Myslim ze W10 se siri hlavne diky OEM instalacim na HW, ktery bezne dnes clovek koupi na krame, BFU si nebude delat downgrade...
Sedmičky už umí bitovou kopii za běhu systému a potom stačí F8 při startu PC, nejelegantnější varianta _________________ .
Kdyby to chtěl někdo integrovat (jeden z mnoha návodů). Celková velikost je o cca 600MB větší, což se s jinými nástroji a ručně přidanými aktualizacemi těžko dosáhne.
P.S. Tak ještě nějaké aktualizace chybí (IE, ActiveX, .NET, doporučené atd.). _________________ .
