Recyklovane sietove karty z Ciny
PříspěvekZaslal: st prosinec 13 2017, 22:57    Předmět: Recyklovane sietove karty z Ciny Citovat
Potreboval som PCI dvojportovu sietovku, nasiel som na eBay dvojportovy gigabitovy Intel za necelych $12. Karta prisla a bola nova - na kontaktoch absolutne ziadne stopy. Zaujimave je ale osadenie karty - konkretne datumy na suciastkach:
Pulse H5007NL: 1537
SST 39VF512: 0236
CSI 93C66: 0315
SC1565IS-2.5: 0352
SC1565IS-2.5: 0914
(na hlavnom Inteli je nalepeny chladic)
Takze nova karta je zjavne poskladana z recyklovanych suciastok. Rozoberaju odpad, co im tam vyvazame, k tomu navrhnu plosak a predaju to naspat Very Happy
Karta funguje, dokonca aj v starych doskach s 5V PCI slotmi. Ak neposrali spajkovanie, tak predpokladam, ze este aj dlho fungovat bude. Podstatna cast vznikla asi rozobratim serverovej PCI-X karty HP/Compaq NC7170.
kód:
00:0a.0 Ethernet controller [0200]: Intel Corporation 82546EB Gigabit Ethernet Controller (Copper) [8086:1010] (rev 03)
        Subsystem: Compaq Computer Corporation NC7170 Gigabit Server Adapter [0e11:00db]
        Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 10
        Memory at ea080000 (64-bit, non-prefetchable) [size=128K]
        Memory at ea040000 (64-bit, non-prefetchable) [size=256K]
        I/O ports at e400 [size=64]
        Expansion ROM at e8000000 [disabled] [size=256K]
        Capabilities: [dc] Power Management version 2
        Capabilities: [e4] PCI-X non-bridge device
        Capabilities: [f0] MSI: Enable- Count=1/1 Maskable- 64bit+
        Kernel driver in use: e1000
        Kernel modules: e1000
00:0a.1 Ethernet controller [0200]: Intel Corporation 82546EB Gigabit Ethernet Controller (Copper) [8086:1010] (rev 03)
        Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 11
        Memory at ea0a0000 (64-bit, non-prefetchable) [size=128K]
        Memory at ea000000 (64-bit, non-prefetchable) [size=256K]
        I/O ports at e800 [size=64]
        Expansion ROM at e9000000 [disabled] [size=256K]
 Soubor:  intel_recycled.jpg
 Velikost:  252.07 kB
 Staženo:  140 krát
Standa99
Založen: Jun 29, 2004
PříspěvekZaslal: st prosinec 13 2017, 23:48    Předmět: Citovat
Stejně je zajímavé, že neopraví ty zdrojové karty, ale takhle to kuchají.
Za 12,95€ jsem bral od nějakého němce (přes ebay) HP dual PCI-E síťovky (x4), ale s Intelem 82571EB, akorát za poštovné chtěl 5€.
Kdyby oběma porty tekly data naplno, tak by PCI nestíhala (133 MB/s).
Ať žije zdejší FOSILOVNA Very Happy
PříspěvekZaslal: čt prosinec 14 2017, 0:11    Předmět: Citovat
Tie zdrojove karty asi nikto nechce, lebo su PCI-X. Mne staci 100Mbit - bude to nahrada dvoch 10Mbit sietoviek - jednej PCI a druhej ISA v PC routeri, kde pri vyssej zatazi nestiha CPU.
Ivan_Ryger
Založen: Mar 02, 2005
PříspěvekZaslal: čt prosinec 14 2017, 0:49    Předmět: Citovat
Nie sú hlúpi. Tuším sa mi páči táto mentalita, bezodpadové hospodárstvo Smile
MetalGod
Založen: May 30, 2006
PříspěvekZaslal: čt prosinec 14 2017, 2:50    Předmět: Citovat
No jen počkej, až si koupíš něco s recyklovanejma elytama Twisted Evil. A určitě je to napadne.
— Winston Churchill
keemo
Založen: Sep 10, 2007
PříspěvekZaslal: čt prosinec 14 2017, 7:17    Předmět: Citovat
nebo prebrousene IO kde nic s nicim nesedi Very Happy
Standa99
PříspěvekZaslal: čt prosinec 14 2017, 7:41    Předmět: Citovat
To že byly zdrojové karty PCI-X, aby rychlost obou portů byla využita, dává smysl, ale i taková karta jde použít do PCI, akorát je trochu delší. Opticky tahle karta vypadá lépe, aby kupující nepochyboval, že to opravdu do PCI slotu zasune, ale jinak to je úplně zbytečná práce. Kolik na tom mají nakonec vývaru, když ty zdrojové karty zadarmo nebudou a následná drbačka (sfouknoutí, plošňák, reball) taky něco stojí? Kdyby na jedné kartě měli litr, tak jo, ale kvůli stokoruny? Spíše bych to chápal, kdyby se nějak pokoutně dostali k těm Intelům 82546EB, které nějaká fabrika nevyužila, kvůli poptávce po PCI-E. Nebo je nakonec vyrobila nějaká fabrika, která ty 82546EB měla zbytečně na skladě, ale to by nebyla žádná recyklace.
PříspěvekZaslal: čt prosinec 14 2017, 8:33    Předmět: Citovat
Netusim, odkial su tie Intely - ale ostatne suciastky zjavne recyklovane su.
PříspěvekZaslal: čt prosinec 14 2017, 9:35    Předmět: Citovat
Když jeden horko těžko shání nějaké obsolete IO a dorazí recyklát, tak to sice nevzbudí nadšení, ale pořád si lze říct, že lepší funkční recyklát, než nefunkční plagiát Smile Jinak v Číně to velmi pravděpodobně funguje tak, že ten, kdo vyrábí tyhle karty z recyklátu, tak recyklované IO kupuje od někoho, kdo je z těch původních desek sundavá, to jedna společnost určitě dohromady nedělá.
Standa99
PříspěvekZaslal: čt prosinec 14 2017, 12:24    Předmět: Citovat
To by bylo divné. Abych měl jistotu, že je ten 82546EB v pořádku, tak ideálně musím vyzkoušet tu zdrojovou kartu (odněkud vytaženou nebo odhozenou) a potom má teprve cenu ten 82546EB sfouknout. Kdyby mi někdo ty 82546EB nabízel ve velkém, tak bych ve funkčnost každého nevěřil, aby to mělo cenu nastrojit "novou" kartu a až potom se dozvědět, jestli je vše funkční. To bych raději dělal vše sám, abych měl před sfouknutím potvrzenou funkčnost. A že by tohle někdo podstupoval kvůli vyrýžované stovce, navíc když je to úplně zbytečná práce, když ta PCI-X karta normálně v PCI funguje?
PříspěvekZaslal: čt prosinec 14 2017, 12:56    Předmět: Citovat
Podla mna ich bude aj v odpade 99 % funkcnych. Takze sa to nahadze do stroja, urobia nove karty a tie sa otestuju (niekto musi nahrat do flash BIOS a do EEPROM MAC adresy).
Habesan
Založen: Jan 12, 2009
PříspěvekZaslal: pá prosinec 15 2017, 11:00    Předmět: Citovat
Vyrábějí se také BGA ZIF objímky (ani nehádejte v které zemi), takže by mohlo jít vyzkoušet i odpájené obvody.
(Nemusí mít platnou revizi.)
