Založen: May 29, 2008 Příspěvky: 54 Bydliště: Trenčín
Zaslal: st leden 05 2011, 0:33 Předmět: Philips DVDR3300 /MasterDVD/
Ahojte,
dostal som na stol tento DVD/HDD prehravac, s nefunkcnym diskom. Podla servisneho manualu sa tam vlozi novy, a do mechaniky sa vlozi Master DVD ktore tam skopiruje alebo vytvori particie. Nema niekdo to DVD? Skusal som najst na nete a nic... Pripadne Image orig. disku.
Cast z manualu:
In case of failure the HDD is replaced by a new unformatted
HDD.
To prepare the HDD for use it must be formatted with a
Master DVD via the Diagnostic software nucleus 2107.
Example:
DS:> 2107
Please insert the Master DVD <OK>
Executing transfer table 1 of 4……..
Please wait… <OK>
210700: Transfer OK
