Dell Latitude D520 - vymena LCD, regulacia jasu
PříspěvekZaslal: út leden 31 2017, 22:26    Předmět: Dell Latitude D520 - vymena LCD, regulacia jasu Citovat
Menil som v notebooku Dell Latitude D520 LCD panel - povodne tam bol Samsung LTN150XG-L06, dal som tam LG-Philips LP150X08(A3).
Uchytenie a zapojenie konektora je rovnake, ale musel som par veci upravit:
- odcvaknut plastove zapadky z konektora na kabli, pretoze nahradny panel ma konektor bez zapadok a zavadzaju
- odmontovat z povodneho panelu drziak invertora a kedze nahradny panel na to nema montazne otvory, tak ho prilepit
Po tomto panel funguje, ale objavil sa problem: regulacia jasu prestala fungovat plynulo, pri zvysovani alebo znizovani (v BIOSe alebo cez Fn+sipky) len preskakuje medzi dvoma urovnami. Na vyriesenie tohoto problemu treba upravit EDID LCD panelu. Dal by sa aj cely skopirovat z povodneho panelu, ale to bolo dobre na testovanie, nechat to tak by som povazoval za prasacinu.
EDID z povodneho LCD Samsung LTN150XG-L06:
kód:
00000000  00 ff ff ff ff ff ff 00  4c a3 58 47 00 00 00 00  |........L.XG....|
00000010  00 0f 01 03 80 1e 17 78  0a 87 f5 94 57 4f 8c 27  |.......x....WO.'|
00000020  27 50 54 00 00 00 01 01  01 01 01 01 01 01 01 01  |'PT.............|
00000030  01 01 01 01 01 01 64 19  00 40 41 00 26 30 18 88  |......d..@A.&0..|
00000040  36 00 30 e4 10 00 00 19  00 00 00 0f 00 00 00 00  |6.0.............|
00000050  00 00 00 00 00 18 ee 02  74 00 00 00 00 fe 00 52  |........t......R|
00000060  44 39 39 37 01 31 35 30  58 47 0a 20 00 00 00 fe  |D997.150XG. ....|
00000070  00 f0 e0 d0 c8 a0 80 50  00 01 01 0a 20 20 00 39  |.......P....  .9|
EDID z panelu LP150X08(A3):
kód:
00000000  00 ff ff ff ff ff ff 00  30 f0 57 06 00 00 00 00  |........0.W.....|
00000010  00 00 01 03 80 1e 16 78  0a 72 b0 96 57 52 87 28  |.......x.r..WR.(|
00000020  23 50 54 00 00 00 01 01  01 01 01 01 01 01 01 01  |#PT.............|
00000040  36 00 30 e4 10 00 00 18  00 00 00 00 00 00 00 00  |6.0.............|
00000050  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 4c  |...............L|
00000060  47 50 68 69 6c 69 70 73  4c 43 44 0a 00 00 00 00  |GPhilipsLCD.....|
00000070  00 4c 50 31 35 30 58 30  38 2d 41 33 00 00 00 26  |.LP150X08-A3...&|
Editovanim a testovanim som zistil, ze na adrese 0x71 je 8 hodnot, ktore zodpovedaju 8 stupnom jasu (asi PWM pre invertor). Ked tam dam same 0xf0, jas je na vsetkych stupnoch minimalny. So samymi 0x00 je jas stale maximalny. Takze staci v EDID nahradneho panelu upravit tychto 8 hodnot podla povodneho panelu: f0 e0 d0 c8 a0 80 50 00 a regulacia jasu funguje.
Neviem, naco sluzia dalsie bajty 01 01 0a, ale pre istotu som ich skopiroval tiez.
Na citanie a zapis EDID priamo v notebooku sa da pouzit edid-rw v Linuxe:
https://github.com/bulletmark/edid-rw
Velous
Založen: Mar 12, 2010
PříspěvekZaslal: st únor 01 2017, 12:13    Předmět: Citovat
Zdaec,měnil jsem 17" display z Ntb ASUS F7se zhořelou grafikou do Ntb 17" EliteBook 8730w,který měl velký flek na monitoru.Kabel Lsvd mi také nepasoval musel jsem jako ty uštípnout zajišťovací drápky kabelu ba dokonce lece začistit jehlovým pilníčkem šířku konektoru (China) a zajistit proti vypadení izolepou.Po nastartování Ntb mi nastavování jasu displaye chodí v krátkém rozsahu a v nejnižsí úrovni mi display nesčerá (nezhasne).Slo by tim EDID zvětšit šířku regulace jasu svitu displaye?
Dík
PříspěvekZaslal: st únor 01 2017, 15:25    Předmět: Citovat
Neviem, ci aj u HP zavisi regulacia jasu od EDID, ale skusit to mozes. Tym edid-rw si uloz EDID tvojho panelu. Z povodneho panelu vytiahnes EDID tak, ze ho bud znovu pripojis do notebooku, alebo (mne sa nechcelo znovu rozobera notebook) pozries do datasheetu panelu a na konektor pripojis 4 droty k nejakemu programatoru I2C EEPROM.
Potom skusis tym edid-rw prepisat EDID tym povodnym - a ked bude regulacia fungovat spravne, mozes s hex editorom zistovat, ktora cast EDIDu to sposobuje.
